Creating a break line
| Mode | Tool | Tool set |
| Modes for Creating single lines | Break Line
 | Dims/Notes |
The Break Line tool creates one of three types of break lines: straight, curved, or arc.
On site models, pads with open edges, sometimes called break lines, can be created using the Site Modifier tool (Vectorworks Architect or Landmark required). See Creating a planar pad from grade limits.
To draw a break line:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited from the Object Info palette.
| Parameter | Description |
| Break Style | Selects the style of the break line (Straight, Curved, or Arc) |
| Break Width | Indicates the width of the break only |
| Break Height | Indicates the height of the break only |
| Break Radius | Sets the radius of the break only |
| Number of Breaks | Indicates whether a single or multiple break should be drawn |
